25 YEARS OF THE RC10 (See page 1)
- Lowgear
- Has thanked: 78 times
- Been thanked: 598 times
Re: 25 YEARS OF THE RC10 (See page 1)
It's not just you. I've known about it since the fairly recent upgrade but thought it was only effecting a thread or two so I didn't bother digging too deep into the cause. Now that I see it's a bit more widespread, I'll see what I can do.
EDIT: I just worked on it for a few hours and I think I finally figured it out. It seems to be an issue with the Cloudflare service we use. I temporarily disabled it, and that seems to have fixed the problem! All the attachments in the offending topics appear to properly load again. Looks like I'll now have to figure out the issue with Cloudflare before re-enabling it again.
Thanks for bringing it to my attention.
- sandkil
- Has thanked: 670 times
- Been thanked: 462 times
Lowgear wrote: ↑Wed Sep 05, 2018 6:00 pm It's not just you. I've known about it since the fairly recent upgrade but thought it was only effecting a thread or two so I didn't bother digging too deep into the cause. Now that I see it's a bit more widespread, I'll see what I can do.
Thank you for your work Lowgear
- Pepito
- Has thanked: 4 times
Hi there!
Can anyone confirm the thickness of the G10 Fiberglass Battery Straps used on the original Edinger Good year RC10s?
I am not sure if I have the correct ones for my car to finally finish off the build.
Somehow, they seem a little thinner than the ones I have seen online.
Living life a 1/4 mile at a time.
I think, it's about time to rename the main topic to "35 YEARS OF THE RC10"...
- slotcarrod
- Been thanked: 41 times
I ain't doin no more!
Rod Littau
- slotcarrod
They are 2.5 to 2.75mm by the naked eye and a good ruler. Sorry for the lack of an exact measurement, my caliper is out side in the cold (-20c).Pepito wrote: ↑Thu Dec 13, 2018 4:07 pm Hi there!
Rod Littau
- Pepito
Thank you for the replies!
I think I may have a reproduction set then. These look to be only 2.0 mm. maybe slightly less.
I have a 98% early Edinger RC10 now. That's heartbreaking!
I found this gem a few years ago. It is near mint too!
The Good Year tires have 99% tread left but are dry rotted and cracked through.
I am also trying to figure out how to "glue" them back together where they are cracked.
I have them currently in a temp and humidity controlled area in my home so they do not get further dry and damaged.
Any suggestions what I can do to the tires (other than leave them alone)?
I might as well throw out there if anyone has a set of real fiberglass battery straps they might be willing to part with so I can complete this gem.
Thanks all!
Thanks all!
- RC10th
- Has thanked: 40 times
- Been thanked: 1018 times
Anyone know when these changed from the diamond to teardrop?
- slotcarrod
Very early Edinger was the only one with diamond, as far as I remember.
Rod Littau
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Rod (still!) in da houseslotcarrod wrote: ↑Sat Apr 06, 2019 12:52 pmVery early Edinger was the only one with diamond, as far as I remember.
- 1048 Views
Last post by trek
- 32 Replies
- 3554 Views
Last post by logikfive
- 47 Replies
- 16088 Views
Last post by WebSteve
- 711 Views
Last post by 59burst
- 1371 Views
Last post by V12
- 32 Replies
- 6086 Views
Last post by erichevy
- 2775 Views
Last post by Racersk
- 2759 Views
Last post by Lonestar
Users browsing this forum: Google Adsense [Bot] and 24 guests
