Clodbuster Soap Opera
Forum rules
Keep it all things Clod!
- RC10th
- Has thanked: 40 times
- Been thanked: 1018 times
Re: Clodbuster Soap Opera
I haven't been looking forward to the last two "jobs" to do on this so it has just sat in a box, lol. I was cleaning up the back room and was a sunny day so I decided to finally peroxide the wheels which has turned into quite a deal, It's super slow going and trying to keep the wheels from floating is proving difficult. Also trying to naturally whiten the rims in the sun isn’t the most efficient method since the rims are so deep. Trying to find a tight fitting container also so you don’t waste much peroxide is also difficult being the rims are so big. I might try to visit a hair salon to buy a bigger quantity.
I think the remaining rims I will have to set up a UV light, and make sure the rim is tied down so it doesn’t float.
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
Nice to see this build going again! Got to be honest...it was depressing when the build stopped over a yr ago☹
- RC10th
Well, I was pretty excited about this until I couldn't find a set of new wheels and stripping the body. I tried paint remover and ezy off on the body and it didn't touch it so I became discouraged
I think I'll just wet sand it, fill the scratches and paint it.
- RC10th
First round of wet sanding done. I will probably prime, fill, and "block" the body twice and call it good. I tried to stay off the belt line as best I could so hopefully it's still crisp
- Has thanked: 2287 times
- Been thanked: 1994 times
Looks kinda cool as is ! Just add a faded red odd wing and some rust and its there
- RC10th
Funny you say that, my wife found it on the dining room table this morning and said it looks cool, and if I could leave it as is and just clear it. I laughed and said ummm... no, it still needs paint. She asked what color and I said it has to be red, she asked why red?
There was a little more to it then that but my phone is giving me the shits so I can't type enough without it freezing.
- RC10th
Note to self..... Don't ever use high build primer/filler ever again
While it worked absolutely fantastic on the flat surfaces it created a lot more work for myself in the way of sanding the more intricate areas. I'm not sure I made it any better at the end of the day, but it will still turn out nice. All of the scratches and dings have been filled and some of the mold lines removed. I should have just primed a few coats and sanded inbetween instead.
All that's left now is a light sand, one or two more light coats of primer, and then I can lay some red paint on it.
- RC10th
Here's the thingamajig I made to keep the stupid wheel from floating...... it works well.
Not sure if it's just me but the ABS plastic seems slow going compared to nylon.
- coxbros1
Keep the updates comin....we all want several a day minimum!
- RC10th
I wish I could work that fast, but someone's gotta pay the bills
- TheDiamondOne
- Has thanked: 1571 times
- Been thanked: 405 times
Dereks right, this build needs to be priority #1.
- Incredible_Serious
- Has thanked: 1406 times
- Been thanked: 861 times
No pressure RJ.... just get off your RRR and Clod up already.
Unless you'd like me to give you a hand.... that'll get it done quicker.
- RC10th
Everything that can go wrong has gone wrong so far with the body, It shouldn't be this difficult
I ran out of primer so I found an older can and splatter splatter
With some luck i'll have it fully prepped tonight to lay some paint tomorrow. Then we'll see just how bad of a job I've really done
Maybe it's a good thing my camera is broken and takes blurry photos......
Almost sounds like excuses..... and I should know.,..RC10th wrote: ↑Thu Feb 04, 2021 7:27 pm Everything that can go wrong has gone wrong so far with the body, It shouldn't be this difficult
- RC10th
I started to paint the body but in true fashion I ran out of paint, and it's not like I can just pop down to the local hobby shop to get more.
The body does look pretty good though so far, one more small step to becoming a Clod. It needs about 3 more coats of red paint, then clear, then black, then.............
- 1142 Views
Last post by BillKrueger
- 4103 Views
- 3600 Views
Last post by Wahrsuul
- 2811 Views
Last post by Seabass
- 1316 Views
Last post by kaiser
- 2763 Views
Last post by Benders
- 1166 Views
Last post by kaiser
- 956 Views
Last post by Nouseforaname
Users browsing this forum: No registered users and 16 guests
