Building a Yokomo YZ10 in 2022 - Help
- Toaster
- Has thanked: 434 times
- Been thanked: 124 times
Re: Building a Yokomo YZ10 in 2022 - Help
A phenomenal score, I wish I started my Yok journey with a beautiful 94 like yours, wow! Welcome to the community.
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
- Frankentruck
- Has thanked: 1590 times
- Been thanked: 1771 times
Are the older style YZ10 wheels still available, or do you think you'll end up with 12mm hex wheels?
- Regular Member
Hello once again everyone,
Sometimes a good thing doesn't come by itself. Earlier this week I managed to get this YZ10 (I think a Works '93).
This one looks to me that was being used as a touring buggy. The front shocks were mounted lower (I already moved them) and it had body posts on top of the shock towers (I already removed them).
This is definitely in rougher shape than the 94 that I bought and needs a thourough cleaning. Some of the bolts are completely stripped so I need to get extra bolts and there seems to be some corrosion on the driveshafts and the motor mount.
Do you guys have any advice on care - how to remove the corrosion etc?
I was thinking of replacing the bolts by hex bolts - are there any hex conversion kits?
The springs also look a little bent and the shocks definitely need to be rebuilt - any alternatives for the springs I could look into?
Thank you for your time and help!
PS - There was no rear sway bar, should there be one?
- Regular Member
Hey @Frankentruck, sorry for the late reply, I did not notice your comment!Frankentruck wrote: ↑Sat Nov 12, 2022 11:58 am Are the older style YZ10 wheels still available, or do you think you'll end up with 12mm hex wheels?
There are some reproductions from JCRacing I think, see below:
https://www.jcracingproducts.co.uk/yokomo-yz10-94
I think I'll get some of these for my cars!
- Toaster
Another beautiful Yokomo, I have literally spent a decade trying to get the two cars you found seemingly in weeks? I am so jealous right now
The second one is a 92’ yokomo and other than the rims/tires looks to be pretty complete and in darn good shape!
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
- Regular Member
Hey @Toaster , indeed! I was very very lucky I think as I managed to "locally" source these two YZ10's in a space of 3 weeks (locally as in within the EU).
I thought I had a 93 YZ10 ahaha (do you know the differences between a 92 and 93?), in the meantime I found out that this most recent YZ10 was used as a "wide touring car" and this was a very common class in Germany before they were discontinued in favour of regular touring cars.
On the next weeks I plan to take it apart, clean it a figure out what needs replacing (I'm hoping not much ahaha).
Then I can start the process of cleaning up the both of them but it will take a little bit I guess. I have a lot of kits to assemble and not a lot of space
- Toaster
Apologies yes, you are correct it is a 1993, a car I personally think is one of the best of all the yz10’s.
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
- 1075 Views
Last post by mamadoesntletme
- 2959 Views
Last post by hondaman
- 1453 Views
Last post by Triniboy
- 1128 Views
Last post by mikea96
- 19 Replies
- 3408 Views
Last post by Jirka
- 1780 Views
Last post by mrlexan
- 1172 Views
Last post by oldskool
- 1014 Views
Last post by Peakey
Users browsing this forum: DotNetDotCom.org [Bot] and 14 guests
